So my problem is, I can't open the driver's door from the inside. I did take off the door panel and checked the opening mechanism and spotted some kind of an arm that pushes a rotor that opens the door linkage. On the passenger side the arm reaches the rotor (or whatever it is called), but there's a gap of about 5mm when I pull the handle on the driver side.
What do I need to adjust/replace to get the arm reaching the rotor? It looks like the pushing rod doesn't get to the position it must go.
Ah yes, 1974 Valiant 4 door
