Installed new turn signal switch. Doesn't Work
jefflock
69 Dart 408 10.08 best pass so far
Kansas
My buddy and I installed a new turn signal switch in my 68 Dart GTS and now nothing is working correctly. It was purchased from Year One. Has any else ran into this? Thanks Jeff :scratch:
Do you have the right part and is the switch grounded.Is the wiring the same and are the contacts being made when the turn signal is on.this can be checked with a ohm meter.If you put back the old one,does it work better? Mrmopartech
Found the problem. There was a direct short on the right side front signal light. I pinched a wire when I installed horns in it. Then I replaced the bulb in it because it was not working. When I did this the bulb socket turned also so it made the wire that was trapped to fray more and become more of a problem. Found it fixed it and working fine. Thanks for help.
