Installing a slant six on a Dart
boxingdude
New Member
summerville, S C
Guys, Im finishind up a new motor my dart. It's about to fire out. I't a 225
Got some wire I don't know what to do with. This is all on the right side. There's a purple one that has a 90 degree angle which I presume is for the water temp. The other two end on the right harness about the place that the dist. coil would. One looks like a coil wire, with ovalish hole in the ring. The other is a brownish with a spade end that's smaller guage than the black one. Could you tell me where they should go?
I believe the brown and black wires with thr spade connectors are for the alternator fields. I will check my car tommorrow after work.
Mod's please ?: could we bump this to /6 forums? Hang tight......
The wire with spade closest to the coil,, would go down to the oil pressure sender on the oil pump..
Temp is purple, oil is grey.
brown to (+) side of coil.
Any wire on the (-) side of the coil would come from the dist'.
Without knowing year model...
Alt field are a single green w/wo additional blue wire(s) .
Black could be horn
