Installing Door Weatherstripping
Blainethemono
Seattle
Hello all, Hope October is starting off good for everybody. I recently purchased some inside door weather stripping, the stuff with the color matching felt.
Is the weatherstripping a pin version where is attaches to rubber & then popped into the appropriate hole in the body?
It appears so, just need confirmation. I have not removed the OEM rubber yet.
Thanks in advance.
63-66 (unsure about 60-62s) 4 doors including Wagons and sedans as well as 2 door sedans - as that is what my wagon is, the weatherstrip all installs over the pinchweld. I had to use a rubber mallet to get it to install in the corners
