Jonathan Paulsen
Active Member
Hi folks, has anyone installed the classic dash insert for the 67-69 darts? If so how did you do it? I'm just a little confused on how it's supposed to fit
Thank you for your input, but I'm really looking for advice from people who have installed it, because it is not that straight forward. I thought it was also until I got it. I'm pretty sure you just have to cut some of the dash frame where the original cluster sits. I just wanted some clarification before I do something wrongLooks straightforward to me? Screws go in upper part(vertically)screws go in lower bottom part horizontally.
EZ PZ
I don't have the ability to post pictures of my dash frame, but I know for a fact that it is not the rally frame. 1. They didn't introduce the rally gauges until 1968, I have a 67. And 2. I pulled the original sweep style cluster out myself.Well post pics of your frame. Can't "piece it together" with only one piece.
Maybe you have rally dash frame?
I'm kind of in agreement with you.I'm pretty sure this is what the cluster you bought fits
BUT.
If you look at the right most gauge. It is near the heater motor switch, but not too close.
The openings for the heater seem to be in stock 67 to 70? Dash location.
The 67 thru 69 bezels and gauge clusters are mostly identical and can swap around (exceptions.... The 67 speedo has screw on cable, and the glove box door has side hinges and radio is post type vs later press on cable and bottom hinge and thumb radio)
So I think it could fit into the 67 thru 70 something dash frame.
And the stock bezel fits over the controlsIf you look closely, you will see that the heater controls mount to the 67 dart frame
So that is only for the 70s dart, the gauge clusters are quite differentHard to tell without seeing the back side of the new cluster. I see what you are getting at though.
Here's the cluster I think will work from the manufacturers web site.
Note the location of the wiper switch and headlight switch. Not sure about the emergency flasher switch location though.
It overlays the metal dash frame. Like the stock bezels doI'm just a little confused on how it's supposed to fit
Yes I have, I'm pretty sure I just have to cut the metal where the original gauge cluster went inJonathon , have you purchaced this dash insert yet?
Just shaving a little bit of the sheet metal that held in the original cluster, not a big dealIf you're cutting metal somethings fd up, good luck.
