Instrument Panel
zitro360
Active Member
Austin
Can an instrument panel from a Slant 6 vehicle work on a V8 engine?
I do believe the instrument panel does not know what engine is up front.
Chime in if I ran wrong.
Dave is right to a point. Check the part numbers for temp. sender and oil press. sender for the old 6 cyl. against the numbers for the donor V8. If they are the same, things should work just fine. If senders are different numbers there might be a problem. Hope someone else can help on that point. Invest in new sending units no matter what. Cheap insurance.
