I bought a 74 Scamp with a rebuilt 318 w/ summit intake and there is antifreeze coming out of the bolt head area. I s this a bad intake casket or a problem with the bolts . NOT casket but gasket lol
Thanks
Thanks
drain the water lever in the block down below the heads and take the bolts out one at a time and put pipe thread sealant on them and re-install and let set per directions on the sealant.
Not to high-jack your thread, But I am having the same problem. Leaks a small amount of coolant on the front side of the intake and runs down the timing chain cover and down the motor. Thanks for the replies to his thread. It might help me too. I noticed a little getting into the oil too. Scary!
John B.
John B.
