Rapid Robert
I just put an alum intake on my 360. I didn't realize until afterward that I forgot to put the throttle bracket under the 2 bolts in the drivers rear. can I remove the bolts & finish it out or do I have to redo everything? I used permatex #2 the brown goo on the ports and RTV on the water ports. iron heads if that makes a difference. thank you for your time. RR
