Screamin demon72
Active Member
I’m having trouble with my 408 la stroker pulling oil out of lifter valley around intake runners and coolant is coming out around the coolant ports. I have tried 2 different intakes, Iv tried every felpro gasket, Edelbrock gasket, summit gasket, and just got a accuseal .125” thick gasket, Iv tried stock bolts, aep bolts, tried cork end seals, no corn end seals and just silicone. I also lightly sanded intake mounting face with a sharpening stone to verify the flange was flat and it was. The head to block angles are identical to the intake angle. Can’t get it to stop leaking oil around ports. Blowing a bunch of blue smoke and plugs are fouling out
