ram250098
69 Barracuda
I am cleaning up the heads to install the intake today and after stripping off the silicone I see two small studs in the center of the valley at each end. Were these used to set the intake correctly in the factory? The intake I took was a LD4B and I could see the studs had dug into the underside of the intake. That doesn't seem right. What do you guy's do? remove them or knock them down further.
Thanks
AL
Thanks
AL
