carfreak6970
Hello Folks,
Currently I am in the process of restoring a 67 Dart with a four speed. Last year I found the console tac - which I am pretty stoked about. As the name implies, this tac is mounted on the console outside of the drivers normal field of driving view. Now what I was thinking of doing would be to add an LED into the tac face that could either light up or flash when the engine hits it's red line.
Now I know there are three wires going into the back of the tac. One is for the light that goes on with the gauge lights, one is for power (or maybe its ground? I dont know, have to look again), and the last one is the signal wire that goes to the coil. Sadly I am not that well versed with electronics, but I am guessing the signal wire varies the incoming (or outgoing) voltage to the tac which allows the needle to rise and lower with engine revolutions. So the LED could easily be tied into that circuit. My issue is how to have the light come on (or start flashing) and stay on (flashing) at a certain RPM (voltage). It should be fairly simple to wire up and get to work as long as you can adjust what voltage the light comes on and stays on at. That way I can fine tune and anyone else could incorporate into any other vehicle with a similar set up. Basically it keeps the stock look but allows the driver to keep the eyes ahead instead of on the tac down below.
Anyone have ideas how to accomplish this?
