mdy2240
New Member
The panels behind the arm rest and window crank are faded. in need of restoration. Do I dye it or paint it. What product should I use?
spray dye. If they are not damaged they will look like new. For best results use the prep sold for whatever die you decide to choose.The panels behind the arm rest and window crank are faded. in need of restoration. Do I dye it or paint it. What product should I use?
