IS BLUE LOCTITE OK FOR CONVERTOR AND FLEXPLATE BOLTS?
CFD244
"THE NEW OLDSMOBILES ARE IN EARLY THIS YEAR"
Northern Ontario, Canada
.......Or do I need something stronger like red loctite?
Thanks FABO
Edit for spelling..."Converter".
Clean and dry the threads first. Brake cleaner.
You use a drop or 2, don't soak all the threads.
Check out the recently released Orange loctite. It's between the blue & red level hold.
As rightly mentioned above, clean threads well before using.
Blue is for any fastener that you may want to remove later. So yes, that's the type fasteners it's made for.
I use ARP Ultra Torque, comes with their bolts. I wouldn’t use red, unless you plan it together forever.
I've been using red loctite for years with no issues upon dis-assembly. I've since switched to the orange mid-grade loctite, just in case the red is too much.
