Is It Backwards? Why Does it Work?
Small Block Mopar Engine
  1. eekvonzipper
    eekvonzipper My Member is Legendary! FABO Gold Member
    380
    298
    Apr 18, 2020
    Cadet, Missouri
    Local Time:
    3:31 PM
    I set my new gears in my chain dot-to-dot (Crank Dot Up/ Cam Dot Down)
    When I set it on the little 273 the Cam Gear was 180 out...
    So I flipped it over in the chain so Both Dot's Were Up.
    I put it all back together and It Fired Right Up!
    It has the old style timing cover with the mark on the Passer side.
    Is it supposed to be this way?
    Did I just get lucky or was the old chain somehow set-up wrong and I copied it?
    • Like Like x 3
    • 67Dart273
      67Dart273 FABO Gold Member FABO Gold Member
      46,595
      14456
      Oct 14, 2010
      Idaho
      Local Time:
      1:31 PM
      This comes up once a month. The cam goes 1/2 crank speed. It's called "ratio." The cam sprocket is twice as big and twice as many teeth as the crank sprocket. So the cam goes 1/2 the speed of the crank. Every other turn OF THE CRANK the dots meet, and every off turn from that, the two dots are on the "other side" of the cam sprocket. 1 turn of the crank, cam dot up, 1 turn of the crank, cam dot down
      Use a straightedge, make darn sure they are in time. The dist does NOT fire no1 when the dots are 'dot to dot' it fires no6. Keep that in mind when you get around to that
      • Agree Agree x 6
      • Thanks! Thanks! x 3
      • Like Like x 1
      • eekvonzipper
        380
        298
        Apr 18, 2020
        Cadet, Missouri
        Local Time:
        3:31 PM
        So, I'm Good? It Does Absolutely fire on One! It Runs Great.
        • Like Like x 3
        • RustyRatRod
          RustyRatRod Lemmie see your b00bs. FABO Gold Member
          67,769
          42061
          Jun 7, 2010
          Georgia
          Local Time:
          4:31 PM
          Lined up dot to dot is timed up on #6. The correct position for #1 firing position is both dots at 12 o'clock.....yet there are few and far between service manuals that show that. The reason is because it's become the industry standard to line the dots up, time the engine correctly, install the distributor at what would be 180 out. That's because it's much easier to determine that the dots are aligned if they are at their closest.
          • Agree Agree x 7
          • Like Like x 2
          • Thanks! Thanks! x 1
          • pishta
            pishta I know I'm right....
            19,147
            8562
            Oct 13, 2004
            Tustin, CA
            Local Time:
            1:31 PM
            ^^ you beat me to it^^^
            It runs great, dont dwell on it. dot to dot is easier to line up but you still time the spark to the TDC of #1 compression stroke.
            • Agree Agree x 1
            • crackedback
              crackedback FABO Gold Member FABO Gold Member
              18,837
              3241
              Aug 7, 2005
              92201
              Local Time:
              1:31 PM
              You sure about both being at 6 o'clock...
              That puts the piston at bottom of bore for #1, IIRC
              I think you meant both marks at 12 o'clock.
              • Agree Agree x 2
              • RustyRatRod
                67,769
                42061
                Jun 7, 2010
                Georgia
                Local Time:
                4:31 PM
                Yeah Thanks. I meant both 12. My bad. I had a brain fart.
                • Like Like x 3
                • RustyRatRod
                  67,769
                  42061
                  Jun 7, 2010
                  Georgia
                  Local Time:
                  4:31 PM
                  I changed that stupid chit. Thanks Rob. lol
                  • Like Like x 2
                  • eekvonzipper
                    380
                    298
                    Apr 18, 2020
                    Cadet, Missouri
                    Local Time:
                    3:31 PM
                    Lol. Thank You Everyone! Especially You Triple R.
                  • j par
                    j par Well-hung Member
                    26,763
                    14387
                    Jul 2, 2014
                    Portland Oregon
                    Local Time:
                    1:31 PM
                    You're on it first correctly and triple-r screws it up then gets all the credit LOL..
                    • Like Like x 3
                    • crackedback
                      18,837
                      3241
                      Aug 7, 2005
                      92201
                      Local Time:
                      1:31 PM
                      Use the "I'm in australia excuse" Everything upside down.
                      • Like Like x 1
                      • RustyRatRod
                        67,769
                        42061
                        Jun 7, 2010
                        Georgia
                        Local Time:
                        4:31 PM
                        That's right. Even toilets go the wrong way. lol
                      • James Clews
                        James Clews Well-Known Member
                        123
                        149
                        Aug 25, 2018
                        Australia
                        Local Time:
                        8:31 AM
                        Rusty! no you guys are upside down , not us! We have not had a corona case in two weeks, how many have you guys had?
                        • Like Like x 1
                        • Agree Agree x 1
                        • RustyRatRod
                          67,769
                          42061
                          Jun 7, 2010
                          Georgia
                          Local Time:
                          4:31 PM
                          Too dang many, James.
                        • dodge71demon
                          dodge71demon Well-Known Member
                          3,399
                          546
                          Apr 29, 2009
                          Indiana
                          Local Time:
                          4:31 PM
                          Thought this would turn into something else but didn't -- good job
                        • krazykuda
                          krazykuda Well-Known Member FABO Gold Member How-To Section Editor
                          57,385
                          23032
                          Aug 20, 2007
                          Orland Park, IL
                          Local Time:
                          3:31 PM
                          Why do you have THREE throttle return springs on the carb??? That could cause some side loading on the throttle plate shaft and cause it to wear in an oval shape over time... I would recommend going with two at the most, three is a little much...
                          Your gas pedal must be so stiff with all of those springs, your leg will look like Quagmire's arm after internet porn....
                          • Like Like x 2
                          • jazak5
                            jazak5 Well-Known Member
                            993
                            454
                            Aug 6, 2015
                            NY
                            Local Time:
                            4:31 PM
                            You live on one of the toughest places on earth !!! Once a penal colony and everything is dangerous or poisonous....COVID-19 is the sniffles !!!
                            :lol:
                            • Like Like x 2
                            • Tooljunkie
                              Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
                              17,169
                              17532
                              Jul 22, 2017
                              Manitoba
                              Local Time:
                              3:31 PM
                              I remember a neighbour and his diesel mechanic buddy doing the same thing on a chevy small block. Picture in manual showed dots together. Says thats how they did it. There were actually words that said turn crank to bring both marks to top before installing distributor. They didnt read that part. I pulled dist, turned rotor 180 and it fired right up.
                              • Like Like x 2
                              • 69FBCuda
                                69FBCuda Life in the Fast Lane FABO Gold Member
                                2,866
                                1518
                                Aug 28, 2014
                                Florida
                                Local Time:
                                4:31 PM
                                Gotta Love that feeling when it's "right" and fires up for the Big purrrrr, might even beat Sex...............:lol:
                                • Like Like x 1
                                • Agree Agree x 1
                                • Cuda416
                                  Cuda416 FABO Gold Member FABO Gold Member
                                  1,234
                                  783
                                  Jun 12, 2014
                                  South, TX
                                  Local Time:
                                  2:31 PM
                                  Well let's see... 25 million, to 330 million people.... You're not even the same size as Texas... soo....
                                  • Like Like x 2
                                  • Agree Agree x 1
                                  • Treblig
                                    Treblig Well-Known Member
                                    6,758
                                    3996
                                    Oct 5, 2013
                                    South Texas
                                    Local Time:
                                    3:31 PM
                                    Here's a couple of cases on me:
                                    • Like Like x 4
                                    • SGBARRACUDA
                                      SGBARRACUDA ROY FABO Gold Member
                                      18,548
                                      7138
                                      Dec 7, 2006
                                      PLANT CITY FL. and PERRY GA.
                                      Local Time:
                                      4:31 PM
                                      'There, I couldn’t have explained it any better.
                                    • krazykuda
                                      57,385
                                      23032
                                      Aug 20, 2007
                                      Orland Park, IL
                                      Local Time:
                                      3:31 PM
                                      You said penal...
                                      Speaking of penal colony and poisonous:
                                      The Lone Ranger has to take a whiz so he stops along the trail to go in the bushes... While in middle of relieving himself a poisonous rattle snake bites him on his 'penal colony'....
                                      He sends Tonto into town to get a doctor... Tonto finds the doctor and he tells him what happened to the Lone Ranger... The doctor tells Tonto that you have to suck all the poison out of the bite...
                                      Tonto rides back to the Lone Ranger and when he arrives, the Ranger asks him, "What did the doctor say???"
                                      Tonto replies, "You're gonna die..."
                                      • Like Like x 3
                                      • Cuda416
                                        1,234
                                        783
                                        Jun 12, 2014
                                        South, TX
                                        Local Time:
                                        2:31 PM
                                        So did they change this on magnums? We did it dot to dot, rotor pointing to #1 TDC and it fired up on the first crank. Am I missing something really basic and got really lucky?
                                      • pishta
                                        19,147
                                        8562
                                        Oct 13, 2004
                                        Tustin, CA
                                        Local Time:
                                        1:31 PM
                                        Here is the physical layout of the cam lobes: the key to the cam points right up the #1 exhaust lobe. The key to the crank points right up the #1 cylinder so dot up in the crank is TDC of the #1 piston (either compression or end of exhaust) . With DOTS UP, your intake is fully closed on the #1.---with DOT TO DOT, your #1 intake valve is open. the intake lobe is about 60 degrees behind the exhaust lobe going clockwise from the front so if the cam key is at about 4:00, your intake valve is open. count back to the #6 intake and I bet its closed (TDC compression) when your DOT to DOT. That's just how it is. Someone can prove me wrong if you show us the cam lobe orientation on a bare cam.
