Is this flex plate okay to use?
bighammer
Northwest Oregon
I bought this a while back, but upon inspection, it appears to have a little wear; I don't know if I should be concerned or not. This should be a balanced flex plate for an exterior balanced 360 to bolt up to my 904 tranny. Is the wear a problem?
Sorry, I can only load one picture at a time. Here's another:
I wouldn't use it. Looks like it was run awhile with loose converter bolts. The mount holes are not round anymore.
Looks a bit rough, last thing you would want to do is replace it once its in there...
... That's just what I thought. Not cool when you buy parts here and the seller doesn't show or describe the damage.:wack:
look at your convertor bolts, if they are 5/16 you are good to go. Most aftermarket convtertors use the 7/16 size and yours is wallowed.
