Is it possible to remove and block this?power
Is the manual box something that’s available after market or should I be searching on this site?Steering with a power box with no fluid flow is more difficult than with regular manual steering. That gear is also likely out of fluid and worn. Either put the correct manual box in it or get the power steering working.
I mean, I go to the gym once in a while. I wouldn’t say that my arms are huge. LOLI’d buy a manual box and the adapter to make the column hook up and be done.
Those power steering gears turn way harder than manual box. You must have arms like Bluto.
That's a ******* balloon animal lolView attachment 1715552103
@PST you want the genie you gotta rub the lampI like the PST manual 16:1 box I have in my 65 dart. I don’t think it’s hard to turn maybe alittle in a parking lot.
