Finally got my 69 Cuda with around 450+lbs of torque, 4 speed, and 4.10 gears running (Yes it is quite an adventure to drive). Finally, found the time to get the 4 speed and all the rest of that stuff put in the car, went from auto to 4 speed. Tried to get it started and found out that my ECU might still be good will get checked, ballast resistor, and ignition switch all decided to go bad over the winter. Right now I have a stock NAPA box installed while I wait for a new FBO box. The engine is no where close to crisp with the stock box compared to the FBO unit, and the thing still wants to twist my frame; really need some frame connectors. Well that is about it for now I will definitely have some questions later.
