it's time to find my rear axle
Transmission and Drivetrain Tech
  1. Andrezinho
    Andrezinho FABO Gold Member FABO Gold Member
    165
    160
    Apr 30, 2020
    Belgium
    Local Time:
    2:53 PM
    it is really for road use and sometimes, very rarely on track
    I was thinking of a:
    Currie Dana 60
    your opinion on the Detroit Truetrac system?
  2. SGBARRACUDA
    SGBARRACUDA ROY FABO Gold Member
    19,562
    7996
    Dec 7, 2006
    PLANT CITY FL. and PERRY GA.
    Local Time:
    8:53 AM
    I'll tell you what my dad use to say to me. "Never be afraid of buying the best, you'll never be disappointed." If you buy a Dana 60 you have the right rear end for what ever direction you take your car. I have used a Detroit locker in the past. Several times, never had a problem.
    • Agree Agree x 3
    • Like Like x 1
    • AJ/FormS
      AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
      20,594
      8032
      Jan 19, 2014
      South-Central Manitoba,Canada, 900ftelevation
      Local Time:
      7:53 AM
      I'm biased towards 8.75s which have drop out center sections that can easily be swapped around in an hour or so. So then you can have several chunks kicking around for different purposes. At one time I had about eight of them, but eventually I bought an overdrive, so sold all the big-number stuff, one by one.... except 4.88s, I still have two of those.
    • Andrezinho
      165
      160
      Apr 30, 2020
      Belgium
      Local Time:
      2:53 PM
      when you change the rear axle ratio, do you also make changes in the automatic gearbox?
    • Andrezinho
      165
      160
      Apr 30, 2020
      Belgium
      Local Time:
      2:53 PM
      I also thought of the Ford 9 "model, with the ease of changing the ratios quite easily.
    • SGBARRACUDA
      19,562
      7996
      Dec 7, 2006
      Local Time:
      8:53 AM
      My 2 cents? if its a Mopar, Dana 60. If it's a Ferd, go 9".
    • Andrezinho
      165
      160
      Apr 30, 2020
      Belgium
      Local Time:
      2:53 PM
      I always dreamed of making my own Dart with a big engine. when I lived in Brazil I had the possibility of doing, but the time passed too quickly. 30 years later I live in Belgium, a nice country, but what shit, to make a simple change of wheels. and when I tell you that USA parts finally arrive here almost 3 times more expensive.
      • Like Like x 1
      • AJ/FormS
        20,594
        8032
        Jan 19, 2014
        Local Time:
        7:53 AM
        That depends on how long it's gonna stay in the car,lol.
        If it's gonna stay; then you would want to change the speedO gear so it's accurate again. and
        Depending on how big a gear change you swapped in, you might want to correct the governor for better-timed auto upshifts, which is not that big a deal to do.
        As you go bigger in gear numbers, like from 3.23, to 3.55, the need for higher stall decreases somewhat..... Unless you like the whiplash of a 2800plus TC, with 3.91s lol. I mean it's kindov addictive.
        I know what you mean about time. The older I get, the faster time seems to go. I'll be 68 shortly and the last 7years have absolutely flown by me.Crap I'm almost half way thru my last quarter.
        • Like Like x 1
        • DoctorDiff
          DoctorDiff Well-Known Member
          297
          207
          Sep 30, 2012
          Polson, MT
          Local Time:
          6:53 AM
          • Agree Agree x 1
          • Andrezinho
            165
            160
            Apr 30, 2020
            Belgium
            Local Time:
            2:53 PM
            normally next week I will receive the full quote with the price here in Belgium.
            Just to give you an idea of the price madness here in europe.
            set of rear leaf springs: in the USA 400 dolars,
            to get it here 1000 euros.
            stainless steel fuel tank: in the USA 260 dollars, once here in Belgium 800 euros.
            It's because I love Dodge made USA too much, because it makes you want to sell everything and buy a Catheram 620R. for 40 thousand euros.
          • Andrezinho
            165
            160
            Apr 30, 2020
            Belgium
            Local Time:
            2:53 PM
            je voulu commander un carburateur FS et apparemment rupture de stock
          • Andrezinho
            165
            160
            Apr 30, 2020
            Belgium
            Local Time:
            2:53 PM
            I wanted to order an FS carburetor and apparently out of stock
          • Andrezinho
            165
            160
            Apr 30, 2020
            Belgium
            Local Time:
            2:53 PM
            hello enthusiasts, I have just made a fairly large order of parts on a site in Germany. Are the same parts that I could order from you but at a better price than by the previous method. I'll keep you posted when the rooms are at my house.
            If it works I control my rear axles.
            probably it will cost me around 6,000 euros at home in Belgium.
            • Like Like x 1
            • crackedback
              crackedback FABO Gold Member FABO Gold Member
              18,884
              3307
              Aug 7, 2005
              92201
              Local Time:
              5:53 AM
            • 408 swinger
              408 swinger FABO Gold Member FABO Gold Member
              2,328
              2164
              Nov 12, 2010
              Iowa
              Local Time:
              7:53 AM
              Sorry, I wouldn't piss on the best part of a 9 inch. I
              Idgaf how popular and how many parts are available. I've seen just as many of those break as anything else. Horsepower robbing junk. Use an 8 3/4 or the 60. If it's just road going, not much hard race, that 8 3/4 will last a long time. It's also the lightest of the three. If you're thinking something big down the road for power, put the 60 in and be done. I'll third the motion for talking to Cass at Dr. Diff.
            • Andrezinho
              165
              160
              Apr 30, 2020
              Belgium
              Local Time:
              2:53 PM
              I already bought the actuating rod of the brake master cylinder.
              I have to see a guy that I work quite regularly, to see how much it will cost me the transport to Belgium
