72SwingerJosh
I have two pair of J heads. I want $100 a pair. They have 1.88 intake valves and also have the hardened exhaust valve seats. You can have them cut out to the 2.02 intake valves and then you would have the hardened valve seats for unleaded gas with the big 2.02 valves unlike using J heads that already have the bigger intake valves from 1970-1971. I also have a set of 2.02 valves I can include for an additional $40 with one set of heads if wanted. I will be vending at Carlisle and can deliver them there. The heads are located in Girard PA if anyone wants to do a local pick up I don’t want to ship at this time. Thanks.
