Jeep 94’ 2.5L ?
General Discussion
  1. 67/6barracuda
    67/6barracuda FABO Gold Member FABO Gold Member
    931
    1120
    Jun 24, 2013
    Sharpsburg, GA
    Local Time:
    1:43 AM
    Hello Team Mopar,
    Going to look at a jeep this afternoon for my 14yr old who will get his permit in June when he turns 15. It needs a head gasket. So I’ll assume the motor is junk and look at maybe a remain. It could be salvageable we will see. It’s the 2.5L 5 speed which I think will be perfect to teach him how to drive stick. I know these 2.5L are about gutless but it will make a great first project for him. Guy wants 3k but I’m not paying that. What else do I need to look at with these Jeep’s? 0502C01F-CD73-45A6-A1FF-BF3DBC83EBF1.jpeg
  2. gzig5
    gzig5 FABO Gold Member FABO Gold Member
    1,722
    1887
    May 3, 2018
    Mequon, WI
    Local Time:
    1:43 AM
    They rust worse that the normally horrible Mopar rust, in my experience. Everything is available but still a PITA and not free.
    • Thanks! Thanks! x 1
    • toolmanmike
      toolmanmike FABO MODERATOR Staff Member FABO Gold Member
      59,768
      47340
      Jan 18, 2006
      Iowa
      Local Time:
      1:43 AM
      2.5? Is that the old Pontiac Iron Duke that GM revived and put in the front wheel drive X bodies? (Skylark, Citation, Fiero, and even the mail trucks) If so, they are very long like engines. We had a 92 Skylark with 200,000+ when we sold it and they drove it for years as a work vehicle.
      • Like Like x 1
      • C130 Chief
        C130 Chief Mechanical Genius
        3,090
        250
        Nov 23, 2005
        Boise, ID
        Local Time:
        12:43 AM
        The 2.5 in the Jeep should be the AMC 2.5. Not the most powerful thing in the world, but should be adequate. The most effective way to boost the performance of any Jeep is through the axle gearing. The 2.5 should have 4.10 gears, but that was for a 28"-29" tire originally. Looks like it has 31" tires on it now so a re-gear is in order. (as a point of comparison my DD is an 05 LJ Rubicon which originally had 4.10 gears and 31" tires. I now run a 33.5" tire and the difference by swapping to 4.56 gears was like night and day). Also, from the picture it looks like some mis-guided soul tried to lift the Jeep with a longer shackle. For safety sake, do something else.
      • 69moredoor
        69moredoor Well-Known Member
        275
        237
        May 5, 2019
        VA
        Local Time:
        2:43 AM
        What year is it?
        The ax-5 is weak and fifth gear usually goes
        baby the Dana 35
        on them the worst is frame rot. Check the rear by where the bumperettes bolt on. Not the rear crossmember the frame rails
        Next the frame where the trans crossmember/skid plate bolts to it
        Check frame by where steering box bolts to it
        check tub by roll bar mounts ...main hoop
      • 67/6barracuda
        931
        1120
        Jun 24, 2013
        Sharpsburg, GA
        Local Time:
        1:43 AM
        I checked it out there is absolutely no rust any where raised the carpets, floors and rear bed area perfect. Frame looks perfect it’s in good shape just the head gasket and the little things that add up with a vehicle that old, 144k miles Georgia jeep. I offered 2500 which he declined. So I’ll sleep on it but might still grab it tomorrow. The block is filled with water once you start it and it starts heating up it dumps it’s coolant into the oil. 4D5E9C0C-A5BE-4C7A-957A-F46CDC0B78A2.jpeg
      • gzig5
        1,722
        1887
        May 3, 2018
        Mequon, WI
        Local Time:
        1:43 AM
        Sharp looking little thing. Kid should like it.
      • 318willrun
        318willrun Utube channel 318willrun
        17,570
        19950
        Sep 13, 2013
        I'm here
        Local Time:
        1:43 AM
        Sharp looking! If it's that solid and no rust, He'd have no problem getting 3k for it here. If it was fixed, they'd ask 6500 here for it.
      • sireland67
        sireland67 FABO Gold Member FABO Gold Member
        9,681
        3954
        Oct 27, 2010
        WV
        Local Time:
        2:43 AM
        I have had alot of jeeps, always buy the one with a clean body.
        Engine wise the 2.5 is an underpowerd pos, the 6 actually got better mileage.
        But the 2.5 is a great engine, if never overheated.
        I would plan on a 500 bucks just to get the engine running right.
        Rebuilt head, water pump and radiator.
      • scatpackbee
        scatpackbee Well-Known Member
        732
        483
        Feb 10, 2007
        Georgetown, Ontario
        Local Time:
        2:43 AM
        Make damn sure the frame is sold at the rear leaf spring back shackle area. Very common area on those for rotting.
        I’ve had a ‘89 YJ for over 16 years which has been a summer cruiser since I bought it and that area got really rotten in what seemed to be overnight.
        I ended up repairing that area with the Autorust Technicians frame caps and rear bumper.
        What a pain in the ass that job was lining everything up.
        8E376370-53AC-42D2-B0A9-5C4149AD014F.jpeg 16F18BBD-ABA6-42FA-88C4-528DCEDB6214.jpeg
        0881BAEF-3ABD-4E5C-9930-FB79A5CFC6A6.jpeg BAE37113-70BA-4CAD-BDA7-A962A54BA4F4.jpeg
      • Max1196
        Max1196 Well-Known Member
        976
        711
        May 12, 2016
        Swift Current SK
        Local Time:
        12:43 AM
        If it is the AMC engine, from past experience, it's not just a head gasket, that 2.5 AMC head was prone to cracking! If it is the 2.5 GM engine, that's a much better unit to work with!
      • RustyRatRod
        RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
        75,342
        51449
        Jun 7, 2010
        Georgia
        Local Time:
        2:43 AM
        Make SURE you lecture him on the dangers of short wheelbase high sitting vehicles. It WILL roll over very easily if he snatches it around.......and he does NOT have to be going fast at all. They were bad enough unlifted, but you really need to hammer on it with him. Not trying to mind your business at all, I would just hate something happening to him. They are real easy to tip.
        • Agree Agree x 4
        • scatpackbee
          732
          483
          Feb 10, 2007
          Georgetown, Ontario
          Local Time:
          2:43 AM
          I vividly remember when I first drove mine I almost clipped a signal light post making a left turn. I couldn’t believe how quickly it turned!
          • Like Like x 1
          • JDMopar
            JDMopar Well-Known Member
            4,139
            3084
            Jan 19, 2012
            Candler, NC/Myrtle Beach, SC
            Local Time:
            2:43 AM
            My sister in law just inherited one about like it, with a 4 cylinder engine and 5 speed. It won't pull a greasy string out of a cats butt, but it gets her around just fine.
            • Like Like x 1
            • 67/6barracuda
              931
              1120
              Jun 24, 2013
              Sharpsburg, GA
              Local Time:
              1:43 AM
              They are 32 12.50 may go down a size or two and maybe 11.50
            • 67/6barracuda
              931
              1120
              Jun 24, 2013
              Sharpsburg, GA
              Local Time:
              1:43 AM
              I got it, turns out it’s just the heater core went bad. I’ll bypass it for now and roll with it. It will be a fun project for him to learn on at 15yrs old. Wish I had one at that age. I get to enjoy his enthusiasm. AB72B4A9-AF2C-4BEA-97DA-3C08A400FFF1.jpeg B33A36B4-6DF7-4426-9194-F7F5541A0A88.jpeg
              • Like Like x 3
              • 69moredoor
                275
                237
                May 5, 2019
                VA
                Local Time:
                2:43 AM
                Every 2.5l I had...swapped a 4.0 throttle body from a junkyard and opened up the manifold to match. Helped
                • 67/6barracuda
                  931
                  1120
                  Jun 24, 2013
                  Sharpsburg, GA
                  Local Time:
                  1:43 AM
                  Been wrenching on my sons jeep today, had an exhaust leak. I read the exhaust manifolds where prone to cracking. They damn sure are. 7041A729-AC3A-4C45-8A06-84607AE19C07.jpeg
                • diymirage
                  diymirage HP@idle > hondaHP@redline
                  24,873
                  21996
                  Oct 12, 2012
                  michigan
                  Local Time:
                  2:43 AM
                  So by now you probably know who makes a header for them ?
                • 67/6barracuda
                  931
                  1120
                  Jun 24, 2013
                  Sharpsburg, GA
                  Local Time:
                  1:43 AM
                  I looked at some but I may just buy a dorman replacement. Is there a tried and true sorta go to header for the 2.5L?
                • diymirage
                  24,873
                  21996
                  Oct 12, 2012
                  michigan
                  Local Time:
                  2:43 AM
                  I have no idea, but im sure someone will chime in shortly
                • 67Dart273
                  67Dart273 FABO Gold Member FABO Gold Member
                  49,693
                  18008
                  Oct 14, 2010
                  Idaho
                  Local Time:
                  11:43 PM
                  Just make darn sure you impress on your son those things are some of the "more dangerous" choices in case of ANY crash. Makes not much difference the angle, and a bar/ cage gives you a false sense I'm talking of course about traffic.
