Uhcoog1
I have a set of Jeep SRT 8 exhaust manifolds I am no longer going to use. These fit great with the AlterKtion. I have the factory K member, and they hit the steering box and the torsion bar is kinda in the way.
The SRT8 manifolds have primary tubes wrapped with a heat shield- you can see in my pictures that I notched into the heat shield on the drivers side manifold to see if I could make them fit my factory steering (didn't make it work). Anyway, there is a small opening in the heat shield that doesnt affect the primaries, but I would weld it shut if I were you (I'm not a good welder- I started to try and decided it was a bad idea).
$170+$30 shipping = $200 shipped for lower 48. In Houston.
