Jegs Gauges
SBeeMan
Crossnore NC
Anyone ever used the Jegs house brand gauges?(water temp,oil pressure etc.) Just wondering if they are good,who makes them for Jegs.
I have a set of the Summit brand which are probably the same as the Jegs....made in china..
they work...
Meh on the jegs and summit gauges, i went with VDO electronic ones for the same price.
I'm looking at new gauges. Which electronic VDO's are the same price as the house brands?!?
Chi Com. I have had such good luck with Autometer over the years that I stick with a known commodity. I also prefer mechanical gauges as they tend to be more accurate.
I use -4 for the oil pressure gauge as the larger dia. line lets the gauge react quicker.
water temp is easy to test with a pan of boiling water and a thermometer. Volt meter is electric , obviously , but they are good parts for a little more $$.
JMO, i wouldn't go VDO. Jegs shows the 6 gauge electronic kit as 570ish dollars.
when you can go to speed hut and get the a better set for a hair over 500 bucks.
