mitch340Duster
'70 Duster. White front bucket seat back cover. Rear bench seat covers. Medallions removed from all.
Plastic front seat back cover. Probably salvageable for a beater car.
Dash pad core.
Small block rocker shafts(2)/arms(13 I think)/Bolts w/separators(5) VERY RUSTY
Oil pump/distributor drive shaft VERY RUSTY
Left rear 1/4 extension panel inside trunk. Top part only, vertical section was cut-off and used. New but extensive surface rust.
Fel-Pro valve seals (new unopened and FREE)
I'm asking 10 dollars for each piece or make an offer. Busy with a lot of stuff so it might take a little while to get the stuff out the door. Wanted to offer it up before discarding it in-case someone can use it.
Located in Manchester, CT. Local pickup is best-case scenario for me.
I don't regularly check FABO PM's so maybe track-down my email addy if you want.
Dash pad core.
