Shainesboostin
Just got the Magnum swap done. 750 carb, headers, new timing chain. Motor had like 160k. Runs great. no smoke. idles at 30psi oil pressure jumps to 50-60 with a good amount of throttle. Been beating on it quite a bit. (I put it together to enjoy it and I do!) Lol, anyways, def gets reved. nothing to crazy. maybe seen a bit above 5k a few times. Had a SLIGHT tick before now, it's noticable. Debating if I should tear it apart or just run it. Sounds like driver side VC...just a tick. Opinions?
Also, if I do replace them, thought about putting on 1.7 rr's, but would that be a bad idea with the old springs?
