Fast01
It's a 517" "B" block with RPM heads, around 11:1 compression, Victor intake, 850 carb, and a Comp solid roller .613"/.613" 262/262 110 lca with 1.6:1 roller rockers. Here's the dyno sheet.
It should be plenty strong...lol. You got the most important stuff done.
They the new pro parts headers?
Did they fix the problem with the collectors facing down and in on one side?
And the plug clearance on #6?
Looks like the one Jegs sells under their own name.What balancer is that?? Is it an SFI piece?
Thanks
I'll have to take some pictures of mine to compare them.
They do hang low under the car. Mine scrape going into my buddies driveway.
We just did a full exhaust on the car and the way the pipes exit crooked and different direction on each side , makes it a challenge.
Make sure you fit the collectors, the 4 into one, before you put them in the car.
I had to sand each pipe so they would slide together easily.
When I did the Dart I didn't do this enough and they went together hard, and now are stuck together and are still in the car.
Nice motor, great numbers! Looks like a low deck stroker, do you have a thread about it somewhere, that I can catch up?
Sorry I wasn't able to get any pics for you today, I should be able to get out to the garage tomorrow. Oh, and thanks for the tips on fitting the collectors. That should save me a ton of aggravation!
Yes, it's an SFI piece. Not sure of the brand though. I sourced it with the stroker kit and don't have the package it came in. It has PB with a circle around it stamped onto the outer rim if that helps.
Thanks! Yes, it is a low deck stroker and no, I don't have another thread with the details. This is my first venture into the world of Mopars. I'm a Chevy convert. Traded my '01 Z-28 for the '68 Barracuda this thing is going in. I will still be using a GM tranny though. I love those 4L80's!
That should move that B`cuda down the track in a hurry!
