Dixie Dart
Will a 1968 Dart big block k frame work on a 1971 Dart
I have a 1969 383 out of a b body the steering and k frame are messed up on the 71 dart but the body is perfect
you can drill them and tap them if the bosses are there. its the only way to use an original big block k-frame and mounts.
probably better off selling the original big block K-frame and grab a 6 cyl or small block one and use schumacher mounts.
Plus if you have a 68 original BB k-frame, you can sell it for some pretty good money. They are worth 350-450.
Yes, I believe the front sway bar is mounted different however. Sounds like a fun project.
HOWEVER, the "Factory" big block Darts/Cuda's used a block specific to these cars and MOST blocks aren't drilled for the drivers side mounting bracket which is special to the 68/69 cars.
