K-H sbp spindle gasket question.
AlV
Crabs in a barrel
new jersey
Hi FABO,
I'm in the process of rebuilding a K-H setup and I'm looking for the gasket that fits on the spindle and sits between the backing plate once it's mounted.
I saw something on the YearOne site but it was described as fitting 73-76.
Will the YearOne pieces described above work? if not does anyone know where I might be able to get them?
Thanks
-AlV
When i was rebuilding these Kelsey Hayes brake systems, i would just cut out gaskets from a sheet of packing foam material that you probably can get at Staples, Office Depot, stores.
