[WANTED] K member for 67-72 Dart 318
JeffreysDart
Redwood City CA
Rating - 0%
0   0   0
Looking for a K member for 67-72 Dart 318. Any condition, must have both mounts. Other areas can be cut/modified, don't care....
Would prefer someone in CA or near CA so shipping is not $$$ (will pay up t0 $50 for shipping) or can local pick up.
'67 K-member is unique (idler arm, one year only). 68-72 were the same far all small blocks. 73-76 can be swapped in with the correct 73-76 motor mounts. Sway bars changed in 1973 (for cars so equipped), but the early bar can be used on the late K-member, but some will need the frame mount holes drilled.
You want a '68-'72 if you prefer to have the biscuit type mounts. The '73 and later is the spool mounts (which IMO is better).
either is fine, this is actually for a mock up in dropping a 1955 Hemi in to a 69 Dart and Ill have to spend time and fab the headers and would prefer not to take out my running motor just to spend weeks/months fabricating to see if it would work in the long run.
I'm in San Jose, just took it out of the car. Front was rebuilt with poly bushings, has new ball joints and new brake calipers too
