72_dart
I just received the k-member reinforcement kit from Firm Feel. I plan on welding up my k-member today or tomorrow. Does anyone have any tip or suggestions, or is there anything that I should know before I start welding?
Corrosion control! Clean it, test fit pieces, weld in 1-2 inch fillets and then move to another area, keeps heat down....The oil from over the years permeates the steel and gets in all the cracks and crevices....
I bought the k member last year. When I first got it home I degreased it and it's just been sitting outside I went out to take off the lca's and strut rods and noticed that there is still quite a bit of oil or grease around where the power steering gear goes. Maybe I'll just try to degrease it one more time. I planned on using a wire wheel on my angle grinder to clean up the surface rust. I guess I'll shoot for tomorrow. If I can't get it clean enough then I'll get it hot tanked and blasted. One question though... Where do the cut washers go?
Thanks 72bluNblu, did you flatten out the the factory tabs up where the front strut rod bushings go?
This is timely information for me with lots of good advice, hot tanking, sand blasting, double checking steering box before welding the supports in there.
Mine was originally a slant 6 k-member. It now has the Schumacher , mounts and a 5.9 Magnum.
Is there any way any way to check it for straightness prior to welding? Not sure how you could ever bend it back one way or the other anyway.
No, although you could. I actually just ran a bead down the backside of that flange to weld it to the K. The '73 up K's actually have flat reinforcements there instead of the ones with the tabs.
Also, I didn't add the reinforcement washers to the fronts of the strut rod mounts. I use adjustable strut rods, and they all use a large metal spacer instead of the typical bushing and washer set up. With the added diameter and thickness of the metal spacer, the extra reinforcing is just extra. If you're going to use a stock strut rod and bushing set up, I'd reinforce it though. But keep in mind that extra thickness may effect the length of the strut rod.
To check for square, measure between opposite corners and they should be the same for square. If they are very far off, the k-member is tweaked.
This.
And welding (heating) may make it out of square. Used a jig when I did mine to make sure it stayed square.
Pics on page 2 of my build thread
http://www.forabodiesonly.com/mopar/showthread.php?t=186036
-Chris
