[FOR SALE] Keith Black Cast Aluminum Oil pump
Wademetzinger
Member
Catoosa, ok
Used but in good shape, Keith Black Cast Aluminum Oil pump. 2 lines go to the pick-ups in the pan and the other 2 go to the remote oil filter adapter. This one has been setup for non-blown application by removing the inner spring in the pressure relief to support 75 – 95 lbs of pressure rather than the 150lbs they make with both springs, so this will work in anything from a 600hp bracket motor to a 1,600hp shoot-out motor or buy a new spring from KB and use it in a blown application.
Also comes with new rebuild kit, o-ring/seal kit received from KB just this week.
These are $750 new from KB, I’ll take $350 shipped for this one.
PayPal accepted
