chickendeluxe
Selling rebuilt and Upgraded Kelsey Hayes 4 piston, disc brake set up with Hard to Get Parts.
Parts should be Cleaned off and Bearings will need Greased and Seals purchased and Installed.
Used on the 1965-72 A body Mopar cars, such as Duster, Dart, Demon, Valiant, and the 65-69 1st and 2nd generation early Barracuda's.
These brakes will fit, work, on the 64 and earlier A body line of cars.
These are the 4 inch, small bolt pattern brakes with new RIGHT HANDED Studs.
**New Set of C-Quence Drilled and Slotted Rotors and Ceramic Pads-
These Rotors are usually on Back order and HARD to Get.
*Cleaned and Detailed Spindles with Correct Bolts and new A2 A6 Bearings and Foam Seals-
*Clean Detailed Backing Plates
*Blasted Painted Caliper Hose Brackets
**A set of DFC , Dynamic Friction Company Ceramic Pads come with the setup and the anti Rattle Clips are included.
**Calipers were Blasted, Painted serviced with new Pistons and Seals.
----Missing a few readily available parts-
You will need a Set of Cross Over Lines- $60 Ebay and Brake Hoses $35, 10" drum inner seals available at Napa or Rock Auto (National 6840S $4.12)
I purchased this set up for my 67 Barracuda as pictured, but have decided not to use since I got Big Bolt Rear Axles and front brakes.
$1100 with all Pictured and Upgraded Parts-
Shipping should be about $80-100 in US-
May be able to Deliver and Meet South down 95 from DC area
