A- body 67-72 are the calipers the same from left to right? Can you swap side to side or are they different. THanks
Not worth the effort, labor time, for machining to do anything like that, as long as calipers are still available to be found and purchased.I have wondered if a left (or right) could be drilled tapped etc to have a bleeder on both sides. I guess you would have to machine for the hose as well.
FYIA- body 67-72 are the calipers the same from left to right? Can you swap side to side or are they different. THanks
Yes there is.Also 65, 66 and maybe 67? Mustangs, don't know if there is a difference in the machining or casting
Depending on the year of the Ford caliper 3/8 or 7/16.I believe the ford ones used a different thread for the line connection.
So the only difference between a right and left side caliper is the bleeder location?
