[SOLD] Kelsey hays 4 piston disk brake setup
schwinger
1972 Dodge Dart Swinger
Fresno, California
Got a spare KH disk brake setup that is just collecting dust and needs a new home. Calipers are used but still in good working order. Missing 3 of the original brake pad retainer tabs on the calipers, just have 2 others tabs from another vehicle on one of the calipers. Brake pads are fairly new. Unfortunately lost caliper mounting bolts so replaced with grade 8 bolts. Rotors were shot so I removed them from the hubs. Will include the used lug but studs. Spindles and hubs are in great shape, cleaned up and painted black. Lower ball joints are used but in good shape, needs rubber boots. Most of the hardware is there just needs new bearings, seals and bearings caps as well as caliper retainer tab
Asking 390 which includes shipping in the states.
Parts located Fresno ca
Can do PayPal or if you wanna pick up in person will work out an arrangement for that.
Are you sure you pmd me because my inbox shows 20% full and I’m already receiving pms for this disk brake setup
Odd
When I try, even now to send you private message it still shows an error message saying that you are full
Oh well,
I think I know the answer to my question since it is on this forum
The parts you show are for an A body, correct?
Just checked, I was able to send a PM to another member
Don't know what to say except may be a system glitch
Erase your PMs you can’t send messages if your box is full. I tested and I can message schwinger but it says your box is full. Hope it helps.
