[WANTED] Kick down linkage
Mayflwr
Active Member
Half Moon Bay Ca.
Rating - 0%
0   0   0
Hello this is Mayflwr. I need the kick down linkage that attaches to the carburetor and the bel crank on the intake manifold for my 66 Dodge Dart V8. Can anyone help me out. Thanks. Mayflwr
I would have a 2bbl bell crank, but, not the 4bbl for a stock '66 only setup. Maybe the front rod for a 2bbl.....I'd have to do some digging.....
i have the 2bbl stuff for 65, let us know what you're looking for and i'm sure one of us has it.
I have a Chrysler 360 with Holley 4 barrel. The carburetor to bel crank linkage would be for a 273 the car came with. The end at the carb would be slotted and the end at the bel crank turned 90 degrees. With that configuration l could modify if necessary. Thanks. Mayflwr
I have a 66 convertible with a 318 and I used the kickdown set up from a 1970 small block that mounts to the manifold works fine, it is not stock looking but it gets the job done This is what I used and I have one for sale
Joe
