The kickdown band adjustment is on the side of the case above and forward of the shift linkage. Loosen the lock nut a few turns holding the adjusting screw so it doesn't turn. Tighten the adjusting screw down using a inch lb. torque wrench to 72 inch lbs. Then carefully using a wrench back off the adjusting screw 2-1/4 turns. Then hold the adjusting screw so it doesn't turn and tighten down the lock nut real good.
