Kickdown linkage for 318/904 combo
Varment
Rochester Hills, MI
Rating - 0%
0   0   0
I have absolutely no parts for a 318 to 904 kick down linkage set up and am hoping to find someone with the full linkage. It would help me out tremendously!
Thanks,
Varment
I have part of one.. the kickdown bar itself, the part that attaches to the intake manifold, and the part where the throttle spring attaches to the intake manifold from the carb. for a four barrel I believe, just dont have the adjustable part that goes to the carb
1968 Barracuda 318/904
does anyone know if the kick-down linkage for a 727 will work on the 904? not steering column lever. I have a console dint know if that makes a difference.
thanks
727 uses a longer trans arm. I have a few complete 904 set ups. I also have an extra rod you can cut and weld to the 904 rod for each.
I actually have all the parts except The Gear Shift Control lever that connects to the lower rod. would you have one or know were to find one.
thanks
Sedanman
How much for a complete set for the 904 if I can't find the Gearshift Control Lever?
B717
