pishta
I know I'm right....
3 rod style. I got both small (right) and B motor models, left. (someone said that the correct big block A linkage has the down rod on the backside of the top pivot, but it still works fine. Had to do with a little extra clearance for an electrical connector??) $60 for the small block and $70 for the B model shipped in USA. The B does NOT have the throttle cable mount on it, you need to run one off the carb base, it was cut off. Paypal welcomed, just send as "gift" and save yourself some nasty fees.
