Hammer
So I've been doing some extensive reading about ignition timing of engines running boost, and from what I have read, knock sensors are the way to go. Apparently the MSD ignition boxes that retard the timing "X" amount of degrees per psi of boost can give you a great top end, but a saugy middle. So my question is: can a bosch knock sensor be installed on a slant 6, and if so where would it go?
