I want to replace the 3 groove rubber isolated crank pulley on my 1967 SBM, factory power steering and factory A/C with a one piece steel or aluminum piece. Anyone have a good supplier I have been unsucessful looking on the internet. Thanks
I have a three or a four groove crank pulley (Need to look to confirm) matched with a 2 groove water pump pulley that I just removed from a running 360. Both are steel and nice shape pm if your interested Jim
Its a 4 groove crank pulley with a matching 2 groove water pump pulley. They were on my 360. Started to clean them up but decided on single groove pulleys instead.
I cleaned out my inbox Tried to PM you and the system said that your inbox is full Yes I am intersted A pic or 2 and some diemensions please It is one piece pulley, no rubber isolator, correct? Thanks in advance
69 down and 70 up is different unless ur trying to match up with the 1970 up aluminum water pump. Kim
