[SOLD] LA Engine kickdown/throttle linkage,throttle brkts,cable etc.
BLKNBLU340DSTR
1971 Duster 340
Livermore,CA
Removed from a stock 1972 318 engine. Throttle hold down bracket was extended for hi-rise intake. All other components are NOT modified. $45-. $13.50 shipping.
Is this for all the linkages and kickdown and will it work with a 340 too? Just doing a v8 swap from /6 so need to make sure nothing missing
This linkage set was actually used on a 340/4bbl engine/Torque-flite clone car, which this car originally had a /6. If you have the small shift lever that attaches to the transmission side, you should be there.
