straightlinespeed
Sometimes I pretend to be normal
Guys what length pushrods should be used in a LA Engine with Magnum Heads. Are they suppose to be 7.650"??
straightline im using 7.750s but thats with solids.1.6 rocker ratio ball to ball
I am using hydraulic lifters so not sure how much that affects the length? Im also using the stock 1.6 ratio rockers and valve train.
I have a off beat question is there any difference in the air gap intakes between LA motors and Magnum motors.
Thanks guys Aaron
Standard hydraulic or hydraulic roller?
