72duster72
can la heads be used on a magnum block
you probably could with some time and money but its not an upgrade as magnum heads flow better then LA ones do
wrong
Lol. Thank you for that, made me laugh. Bigger valves don't always mean better flow!
wrong
I did it on my son's engine by drilling and tapping a pipe thread fitting in the accessory bolt hole, then angle drilling 1/8"down the rear pedestal mount to intersect. Plumbed this with steel tubing to a tee at the pressure sender hole by the distributor. Similar to how it's done on the Big Blocks.
