Has there even been a factory roller rocker for the 318 non Magnum block? Building a Pure Stock/IHRA motor ('80 318 4BBL) and it allows any OEM adjustable rocker. Trying to avoid using the 273 style rocker if I can. Thanks
no on the rockers and for adjustable your stuck with the 273 ones witch aint that bad .Has there even been a factory roller rocker for the 318 non Magnum block? Building a Pure Stock/IHRA motor ('80 318 4BBL) and it allows any OEM adjustable rocker. Trying to avoid using the 273 style rocker if I can. Thanks
