LA vs Magnum Gasket/Seal Compatibility
Gimike812
Tucson AZ
Ok so this may be a dumb question but I have a complete LA engine seal kit from a project that got scraped, I now have a magnum 5.2L.
Are rear main seals the same?
Can I use head gaskets from this kit?
I understand the timing cover, oil filter housing, water pump gaskets are the same, and I know I need a magnum 1 piece oil pan gasket and the magnum valve cover gaskets for the swap.
Yes...you can use the head gaskets.....
Fel pro has two different part numbers for rear main seals.....dont know the difference...
