[SOLD] large mopar collection for sale/ posting for a friend
have an inventory of thousands of Mopar parts collected over my 51 years in the Mopar hobby. Sadly, I am losing my storage facility and therefore everything must go. There are way too many parts to list, but they range from complete 440 engines down to clock adjusting knobs. Mirrors, power window motors, seat belts, emblems, transmissions, differentials, motor mount brackets, air cleaners, fenders, doors, trunk lids, glass, manifolds, moldings, heater boxes, seats, clips, knobs, radios, engine parts, etc. Some new and NOS parts.
I will make a very attractive deal with the first person to offer to take it all. The parts are located in Vernon and Armstrong, BC.
This is just a very small sampling of the parts included. There are thousands of small parts as well.
Hi Fabo members . Vic is a great mopar guy and a wealth of knowledge . he also has A body parts in this collection as well. feel free to check out his website or give him a call.
sorry guys the pics didnt load. there was only a few anyway i would g on vics website r call for more information.
Here's his website: http://web.mac.com/vpporcher/Site/Home.html
His parts list:
Alphabetical Parts List
This list is approximately 10% of the total parts I have available. Please contact me with your needs.
A/C compressor, V2 style, 70's NY QTY 2EACH $20.00
adapter, oil filter to block, c/w nut, SMALL BLOCK QTY 2EACH $10.00
Air box, vent, interior, 69 B body (69-70?) QTY 1EACH $10.00
air cleaner assy, 1957 Chrysler 354/392 JH QTY 1EACH $150.00
alternator, Leece-Neville 100 amp QTY 2EACH $10.00
Arm rest base, 10", chrome, (replating core) QTY 1EACH $5.00
Arm rest base, 16.25", chrome, (replating core) QTY 2EACH $5.00
Arm rest base, black, 10", very good QTY 2EACH $10.00
Arm rest base, chrome, 13", good QTY 2EACH $20.00
Arm rest base, tan, 13", fair (okay for replating core) QTY 4EACH $10.00
Arm rest, 10", black, front , B body, very nice QTY 2EACH $25.00
Arm rest, 13", left, turquiose, fair QTY 1EACH $10.00
Arm rest, 13", right, turquiose, nice QTY 1EACH $40.00
Arm rest, 9.5" left, med. blue, w/ ashtray, fair QTY 1EACH $15.00
Arm rest, 9.5" left, tan, w/ ashtray, fair QTY 1EACH $15.00
Arm rest, black,right front, 13" MINT QTY 1EACH $40.00
arm rest, rear, w/ashtray, black, pair R&L MINT QTY 1EACH $40.00
arm rest, rear, w/ashtray, red, pair R&L QTY 1EACH $30.00
Arm, wiper, Correct Mopar, 15.5", most models QTY 0EACH $15.00
Arm, wiper, Correct Mopar, 18.5", various models, C body QTY 2EACH $10.00
Ash tray, bezel, rear arm rest, all, mint, pair R&L QTY 2EACH $40.00
axle, 7 1/4 a-body c/w 2.94 open diff, Cuda QTY 0EACH $0.00
axle, Dana 60 truck, complete QTY 1EACH $100.00
axle, Dana 70, 3.54 open, 3/4 - 1 ton truck, complete QTY 1EACH $500.00
axle, front, solid, c/w brakes & spindles, A100 van QTY 1EACH $100.00
axle, hsg, 8 3/4, truck, w/axles, no backing plates, no pig QTY 1EACH $100.00
axles, Yukon, A body large bolt pattern c/w bearings QTY 0EACH $150.00
Bearing,steering col., w/ rubber ring, mint all w/o tilt QTY 1EACH $45.00
bell housing , 1964 BB , B-body 10.5" style, repaired QTY 1EACH $200.00
bell housing, SB, alum, w dust shields, truck only QTY 2EACH $75.00
Bezel, antenna, cast # 2889924 2 piece QTY 2EACH $15.00
Bezel, door lock knob, chrome QTY 3EACH $4.00
bezel, heater control, ctr of dash, 69 Valiant, mint QTY 1EACH $20.00
bezel, ignition sw, plastic, green, 69 Valiant & others QTY 1EACH $15.00
Bezel, remote mirror control knob, 2999001, 66 & up QTY 2EACH $10.00
Bezel, remote mirror control, cast # 6027749 QTY 1EACH $10.00
Bezel, seat back release, upper, 68 C body pair, w/ screws QTY 1EACH $40.00
Bezel, T/light, 69 Sat/RR, cast #2930256, decent QTY 3EACH $40.00
Bezel, T/light, 69 Sat/RR, cast #2930257, decent QTY 3EACH $40.00
Bezel, window crank, black plastic, thick QTY 5EACH $2.00
Bezel, window crank, black plastic, thin QTY 5EACH $2.00
block, bare, 400, hot tanked QTY 2EACH $200.00
Bolt set, complete for door inside, regulator, stops, etc. MINT QTY 1EACH $10.00
bolt, brake pedal pivot w/nut, special bolt w/ O-ring QTY 2EACH $10.00
bolt, bucket seat hinge, special shoulder bolt QTY 0EACH $3.00
Bolt, bumper bracket, 68 C body & others, w/ washer & nut QTY 4EACH $2.00
Bolt, crank pulley, all V8, correct, set of 6 QTY 1EACH $10.00
bolt, dist hold down BB, CORRECT, QTY 1EACH $3.00
Bolt, distributor hold down, SB, correct QTY 1EACH $2.00
bolt, door hinge, CORRECT MOPAR QTY 9EACH $1.00
Bolt, front door vent frame, special, 5/16 x 13/4" NC QTY 2EACH $2.00
Bolt, front door vent frame, special, 5/16 x 2 1/4" NC QTY 2EACH $2.00
bolt, frt shock, lower, CORRECT MOPAR, set of 2 w/nuts QTY 0EACH $8.00
bolt, hood mounting, CORRECT MOPAR, set of 4 QTY 1EACH $6.00
Bolt, horn bracket, Mopar Correct QTY 4EACH $2.00
Bolt, intake manifold, Big Block, correct QTY 0EACH $1.50
bolt, rear shock, upper, CORRECT MOPAR, set of 2 w/nuts QTY 1EACH $6.00
Bolt, spare tire holder, A body, 6" plated as new QTY 1EACH $10.00
bolt, steering box mount, CORRECT MOPAR QTY 15EACH $2.00
Bolt, trans rear mount, correct , most models w/ spacers QTY 2EACH $2.00
bolt, trunklid mounting, CORRECT MOPAR, set of 4 QTY 1EACH $6.00
brace, steering col. To dash, 68-69 A body QTY 1EACH $10.00
Bracket, coil mount, big block, plated as new QTY 1EACH $10.00
Bracket, distributor hold down, small block, plated as new QTY 3EACH $10.00
Bracket, heater hose retainer, BB, alternator mount QTY 1EACH $15.00
Bracket, heater hose retainer, loop style, fender mount QTY 1EACH $10.00
Bracket, inside mirror mount, 68-70 B body QTY 1EACH $5.00
bracket, shifter bell crank mount on auto trans, A body QTY 1EACH $8.00
Bracket, timing mark indicator, small block, with bolts QTY 1EACH $10.00
bracket,distributor hold down, BB, replated as NOS QTY 4EACH $20.00
Brake booster assembly, 1968 C body, will fit others, MINT QTY 1EACH $150.00
Brake booster, 2 bolt m/cyl, F/W bolts, 3.375" w x 3.5"h QTY 1EACH $75.00
bumper, front c/w brackets, 1971 Challenger, nice, JH QTY 1EACH $150.00
bumper, front, c/w brackets, 1970 Charger 70# wt. QTY 0EACH $0.00
bumper, rear c/w brackets, 1971 Challenger, nice, JH QTY 1EACH $150.00
Cable, air vent, 68-70 B Body, Left, good QTY 1EACH $25.00
Cable, air vent, 68-70 B Body, Right, good QTY 1EACH $25.00
Cable, air vent, 68-70 B Body, Right, repairable QTY 1EACH $15.00
cable, glove box door retainer c/w special screw QTY 1EACH $5.00
Cable, throttle, 68 Charger, ~ QTY 0EACH
Choke actuator assbly, bi metallic, 69 318 2bbl QTY 1EACH $10.00
Clip, belt molding, several models QTY 15EACH $1.00
Clip, heater box assembly (holds box halves together) QTY 7EACH $1.00
clip, heater control cable clamp QTY 7EACH $1.00
Clip, hood insulation retainer QTY 20EACH $0.50
Clip, interior roof molding, headliner retainer QTY 5EACH $1.50
Clip, lock rod, door QTY 4EACH $2.00
Clip, rocker molding, 68 Newport, set of 23 QTY 1EACH $25.00
Clip, rubber splash shields, all models, 1" long QTY 6EACH $1.00
Clip, rubber splash shields, all models, 1/2" long QTY 6EACH $1.00
Clip, set belt storage, black plastic, single, B body QTY 0EACH $9.00
Clip, shifter linkage, "G" shape QTY 2EACH $2.00
Clip, trans cooler lines at starter bolt, various QTY 3EACH $3.00
Clip, W/S lower molding, 66-68 C body QTY 8EACH $1.00
Clip, wiring harness, under dash 7"tab QTY 1EACH $5.00
Clips, door latch rods, special MOPAR, misc, inquire appl. QTY 5EACH $1.00
Coat hanger bracket, black, w/screw, 68 C body & others QTY 1EACH $5.00
Coil, ignition, 12V new QTY 1EACH $30.00
column, steering, 1977 Ramcharger, w/ign key. QTY 1EACH $40.00
column, Steering, A body, 69 Valiant,column auto QTY 1EACH $75.00
column, Steering, A body, 70 & newer, for floor shift QTY 1EACH $200.00
column, Steering, A body, 70 & newer,column auto QTY 4EACH $50.00
column, Steering, tilt, truck, 80's, auto QTY 1EACH $50.00
condensor (capacitor), distributor, all new QTY 1EACH $5.00
Cord, engine block heater, NOS, all QTY 2EACH $10.00
cross bar, hood latch support, 69 Satellite(header panel) QTY 2EACH $50.00
cross member, trans mount, 67-70 A body, auto trans QTY 4EACH $50.00
cross member, trans mount, 67-70 A body, Manual trans QTY 1EACH $50.00
dash mounting screw set, CORRECT, all models QTY 1EACH $10.00
Dash mounting screws, compl set, top & sides, MINT QTY 1EACH $15.00
Defogger assembly, rear. , complete QTY 1EACH $100.00
diff, 8 3/4, 489 housing,3.23 open QTY 1EACH $200.00
diff, 8 3/4, 741 housing, rusty- for core only QTY 1EACH $20.00
Distributor cap, black, V8, Mopar, (alum) new HD QTY 2EACH $25.00
Distributor cap, black, V8, Prestolite, (cast iron) new HD QTY 2EACH $35.00
Distributor cap, Tan,Dual point, Hemi, MW, 340 Prestolite QTY 7EACH $40.00
Dome light 4" round, common QTY 4EACH $10.00
door latch actuator rod,R & L, c/w clips, all 60's & 70's QTY 1EACH $20.00
door latch assy, 68 C body, left, as new QTY 1EACH $25.00
door, 1968 Charger L, bare, decent QTY 1EACH $300.00
door, 1968 Charger R, bare, decent QTY 1EACH $300.00
door, glove box, 69 Valiant Signet, mint QTY 1EACH $20.00
door, Left, 1969 Satellite & RR, bare, rust free SALE PRICE QTY 1EACH $125.00
door, Left, 1969 Satellite & RR, complete fair SALE PRICE QTY 1EACH $75.00
door, Right, 1969 Satellite & RR, complete fair QTY 1EACH $75.00
doors ,c/w glass, regs, handles, left, 1970 Dart/Swinger QTY 1EACH $100.00
doors ,c/w glass, regs, handles, right, 1970 Dart/Swinger QTY 1EACH $100.00
Driveshaft, many styles & lengths in stock, inquire, each QTY 20EACH $125.00
Emblem, 68 Ñewport door panel, pair as NOS, 2789790 QTY 1EACH $20.00
Emblem, I M P E R IA L, letters, hood 71, w/nuts, set QTY 1EACH $20.00
Emblem, V EIGHT , fender mount, cast # 2579612 QTY 2EACH $15.00
engine core, 440, 1973-1975, w cast crank QTY 4EACH $400.00
extension hsg, rear qtr, 69 Satellite, RR, right QTY 1EACH $40.00
extension hsg, rear qtr, 69 Satellite, RR,left QTY 1EACH $40.00
Extension, rr qtr panel, 69 Ply B body, #2902363, R, mint QTY 1EACH $50.00
Extension, rr qtr panel, 69 Ply B body, #2902369, L mint QTY 1EACH $50.00
fan, 7 blade c/w clutch 20" C body only QTY 3EACH $50.00
fender splash shields,1964-1965 Barracuda,front, f/glass QTY 2EACH $10.00
fender, left, 1969 Charger minor rust QTY 1EACH $300.00
fender, left, 1970-74 Duster rust free QTY 2EACH $300.00
fender, right, 1970-74 Duster rust free QTY 2EACH $300.00
fender, Right,1967 Belvedere II, minor damage, no rust QTY 1EACH $200.00
Filter, fuel pick up tube, 3/8" Hemi & 440 HP NEW QTY 3EACH $29.00
Filter, fuel pick up tube, 5/16" all exc Hemi & 440 HP NEW QTY 1EACH $29.00
Float, fuel sending unit, all models, NEW QTY 1EACH $17.00
floor hump, 4 spd, A body, rusty but useable QTY 1EACH $50.00
floor hump, 4 spd, fibreglass, 80's truck QTY 1EACH $20.00
flywheel, 340 neutral balance, needs turning JH QTY 2EACH $75.00
flywheel, 340, 440, 383 neutral balance, needs turning QTY 1EACH $100.00
Glide, hood & trunk, torsion spring,B body QTY 1EACH $5.00
Grille, 1962 Valiant, decent QTY 1EACH $100.00
Grille, 1965 Valiant, decent QTY 1EACH $100.00
grille, 1973 Challenger, driver quality, small crack JH QTY 1EACH $150.00
grille, 69 Valiant, c/w headlight bezels, good driver cond. QTY 1EACH $100.00
grille, c/w headlight doors, 1968 Super Bee/ Coronet, Nice, JHQTY 1EACH $300.00
Grommet, antenna wire to body QTY 1EACH $2.00
Grommet, valve cover, breather new QTY 1EACH $8.00
Grommet, valve cover, PCV new QTY 1EACH $8.00
Guide channel, plastic,frt dr window, 68-70 B&C QTY 1EACH $15.00
Guide, elec w'dw harness, body to door, LT, 66-68C body QTY 1EACH $5.00
Guide, elec w'dw harness, body to door, RT, 66-68C body QTY 1EACH $5.00
Guide, white nylon, frt dr window w/strip QTY 2EACH $10.00
Handle, door , inside, LEFT, Argent finish,2935295 QTY 0EACH $10.00
handle, door, exterior, left, 68-70 B&C body, $10 & UP QTY 3EACH $10.00
handle, door, exterior, right, 68-70 B&C body, 2 OK 1poor QTY 2EACH $10.00
handle, door, inside 68-70 B&C body, left, MINT QTY 1EACH $20.00
handle, door, inside 68-70 B&C body, right, MINT QTY 1EACH $20.00
Handle, door, inside, LEFT, 68 & up, B body, 2935215 QTY 3EACH $10.00
Handle, door, inside, RIGHT, Argent finish, 2935294 QTY 0EACH $10.00
Handle, door, inside,RIGHT, 68 & up, B body, 2935214 QTY 4EACH $10.00
Handle, vent window crank, 68-70 C body MINT QTY 2EACH $10.00
Handle, window crank, 68 - up, $5 to $20 QTY 12EACH $20.00
Harness retainer clips, misc, dash & floor, w/ screws QTY 8EACH $2.00
Harness, elec window switch, RT 1/4. PN 2822325 Mint QTY 1EACH $40.00
harness, wiring, 68-69 A body, A/T neutral safety sw QTY 1EACH $5.00
harness, wiring, complete dash, 69 Valiant QTY 1EACH $100.00
harness, wiring, complete under hood, 69 Valiant QTY 1EACH $40.00
harness, wiring, trunk light, c/w switch, all models QTY 1EACH $10.00
Head rest, A body bench seat, 69 & up, GOLD, pair QTY 1EACH $60.00
headers, RB, 1 7/8" primary, B-body new QTY 1EACH $100.00
headers, RB, 2" primary, B-body JH QTY 1EACH $85.00
heads, BB, 452, 906, 902 casting, bare QTY 20EACH $50.00
heater box, complete, 68-70 B body QTY 2EACH $75.00
heater box,1968 C-body complete, mint QTY 1EACH $50.00
heater controls, 69 Valiant, c/w cables & switch, very good QTY 1EACH $50.00
Hinge pin repair kit W bushings, ~ QTY EACH
Hinge, upper door, 69 -70 B body QTY 1EACH $30.00
hinges, hood, pair, 68-70 B body QTY 6EACH $30.00
hood bulge panel only, w/chrome pces, 1969 S/Bee JH QTY 1EACH $75.00
hood remote release cable kit, various Mopar QTY 4EACH $25.00
hood, 1968 Chrysler Newport MINT QTY 1EACH $100.00
hood, 69 Sport Satellite, good QTY 1EACH $100.00
Horn button, Chrysler, black vinyl. MINT QTY 1EACH $75.00
Horn button, DODGE, chrome & black, PN 2925420 QTY 1EACH $40.00
Horn, Lo, Sparton, 74 B & C BODY QTY 1EACH $10.00
Horn, pair, Hi-Lo, MOPAR, application ??? QTY 1EACH $30.00
Horn, pair, Hi-Lo, Sparton, 65 VAL, CUDA DART QTY 1EACH $40.00
Horn, pair, Hi-Lo, Sparton, 69 SATELLITE, rusty QTY 1EACH $20.00
Horn, pair, Hi-Lo, Sparton, 77 B & C BODY QTY 1EACH $20.00
Horn, pair, Hi-Lo, Sparton, 92 truck QTY 1EACH $30.00
Horn, pair, Hi-Lo, Sparton, Model U, 68-70 All QTY 1EACH $50.00
horns, pair, 69 A body, c/w brackets and bolts QTY 1EACH $40.00
Hose, exhaust heat to A/Cleaner, new QTY 2EACH $5.00
Hose, headlight door actuator, 68-69 Charger, CORRECT QTY 2EACH $5.00
housing, tail light assy, 71 Challenger left JH QTY 1EACH $150.00
Housing, thermostat, B & RB eng. All QTY 1EACH $5.00
Housing,T/light, 69 Sat/RR, cast # 2930250, R, good QTY 3EACH $10.00
Housing,T/light, 69 Sat/RR, cast # 2930251, L, good QTY 3EACH $10.00
Ignition lamp time delay module w/ socket QTY 1EACH $10.00
instrument cluster c/w bezel, 69 Valiant, 26,434 miles, nice QTY 1EACH $50.00
Knob and shaft, clock reset, 2.5" long QTY 1EACH $10.00
Knob, clock adj, various QTY 1EACH $10.00
Knob, console shifter, w/spring, chrome, 66-69 fair QTY 1EACH $15.00
Knob, door lock, interior, anti theft style QTY 5EACH $1.00
Knob, heater control, black plastic, various models QTY 0EACH $2.00
Knob, inside lock release, black QTY 3EACH $2.00
Knob, inside lock release, chrome Short style QTY 3EACH $4.00
Knob, inside lock release, chrome, MINT QTY 3EACH $5.00
knob, seat adjuster latch, chrome, most models QTY 1EACH $5.00
Knob, seat back release, (small chrome) QTY 3EACH $10.00
Knob, seat back release, C body buckets, chrome QTY 2EACH $10.00
Knob, shifter, HURST T- Handle, w/ nut QTY 1EACH $25.00
Latch, door, left, 68 C body, mint, c/w rods QTY 1EACH $40.00
latch, hood primary, 69 Valiant QTY 0EACH $10.00
latch, hood, 68-70 C body, MINT QTY 1EACH $20.00
latch, hood, secondary, 68 C body (may fit others) QTY 1EACH $10.00
latch, hood, secondary, 69 Valiant, (May fit others) QTY 1EACH $5.00
lens, tail light and housing, left, 1969 Road Runner QTY 1EACH $50.00
lens, tail light assy, 1971 Challenger, left JH QTY 1EACH $150.00
lens, tail light assy, 1971 Challenger, right JH QTY 1EACH $150.00
lever, console shift, upper bell crank, B&C body 68-70 QTY 1EACH $10.00
Lever, inside dr release w/spring,LT, most models 68 & up QTY 1EACH $25.00
Lever, inside dr release w/spring,RT, most models 68 & up QTY 1EACH $25.00
Lever, signal switch, 65 & up QTY 1EACH $5.00
Lever, throttle actuator, w/ cable, 68-79 B body QTY 1EACH $30.00
Light assembly, back up, 69-70 A&B QTY 0EACH $0.00
Light assembly, license plate, 65 up, common QTY 1EACH $20.00
light assembly, license plate, 68-69 A body, rusty QTY 1EACH $5.00
light, marker, 68 C body only, amber, pair QTY 1EACH $20.00
light, marker, 68 C body only, red, pair QTY 1EACH $20.00
light, signal, c/w hsg & lens, 69 Valiant, left, cracked lens QTY 1EACH $5.00
light, signal, c/w hsg & lens, 69 Valiant, rt, good QTY 1EACH $15.00
Liner, glove box, 68 C body, MINT, QTY 1EACH $20.00
Lock set, 69 A body, ign, doors, trunk, WITH KEYS QTY 1EACH $50.00
Lock tab, 8 3/4 diff axle adjuster ~ QTY 0EACH $20.00
Lock, door, Mopar original, L&R pair w/ clips, no key QTY 1EACH $20.00
Lock, glove box, 1967 C body and others, W/KEY QTY 1EACH $20.00
Lock, glove box, 1968 C body and others, W/KEY QTY 1EACH $20.00
manifold, exhaust, 2205535, Rt, 62-66 383-426W-413 QTY 1EACH $100.00
manifold, exhaust, 2465877, Rt 318 poly, Very Good QTY 1EACH $75.00
manifold, exhaust, 2465877,Lt, 318 poly, Very Good QTY 1EACH $75.00
manifold, exhaust, 2806900, HP 440, Rt, 10-17-67 QTY 1EACH $200.00
manifold, exhaust, 2843992, HP 440, Lt, 8-?-67 QTY 1EACH $200.00
manifold, exhaust, 3789103, 440 truck, w/ heat riser QTY 2EACH $100.00
manifold, exhaust, 3789103, 440 truck, w/o heat riser QTY 2EACH $100.00
manifold, exhaust, 4006741, Lt 318-360 A body QTY 1EACH $100.00
manifold, exhaust, 66-69 BB, RH 2532464, w/HR valve QTY 3EACH $25.00
manifold, exhaust, 77 BB, LH 3830800, Good flow QTY 1EACH $50.00
manifold, exhaust, 77 BB, RH 4041468, Good flow QTY 1EACH $50.00
manifold, exhaust, LH 53010187,97 318/360 Dakota QTY 1EACH $50.00
manifold, exhaust, RH 53010186,97 318/360 Dakota QTY 1EACH $50.00
manifold, exhaust,65-69 BB, LH 2463107 QTY 2EACH $25.00
manifold, exhaust,R&LH 3830684, 318/360 truck QTY 2EACH $50.00
manifold, Intake, 2206000 413-440, 1962-66, 11-23-65 QTY 1EACH $75.00
manifold, Intake, 2206000 413-440, 1962-66, 3-30-66 QTY 1EACH $75.00
manifold, Intake, 2806178, 440 HP, 1967-8, 4-28-67 QTY 1EACH $120.00
manifold, Intake, 3462848, 340, 1970, 08-08-9, AVS QTY 1EACH $150.00
manifold, Intake, 3512501, 71 440HP QTY 1EACH $100.00
manifold, Intake, 400, T/Q, cast # 3830949 1978 QTY 1EACH $75.00
manifold, Intake, 4041231, Slant 6 1 bbl,Aluminum QTY 1EACH $25.00
manifold, Intake, 4173915, 360HP, TQ QTY 1EACH $75.00
manifold, Intake, 440, T/Q, cast # 3830733 after 1974 QTY 1EACH $50.00
manifold, Intake, 440, T/Q, cast # 3830736 QTY 1EACH $75.00
manifold, Intake, Slant 6 4 BBl Clifford QTY 1EACH $100.00
manifold, Intake, Super 6 2 bbl, c/w Holley carb QTY 1EACH $100.00
manifold, Intake, Super 6 2 bbl, c/wCarter carb & Ex man QTY 1EACH $125.00
manifold, Intake, 2806301, 383HP, 1968, QTY 2EACH $125.00
Mirror, inside rear view, Day/Night, 1968 & others, MINT QTY 1EACH $60.00
Mirror, inside rear view, Day/Night, B & C body, good QTY 1EACH $25.00
Molding, drip rail, front connector 68-70 B body, QTY 0EACH $10.00
Molding, drip rail, rear curved end, 68-70 B body, L QTY 0EACH $20.00
Molding, drip rail, rear curved end, 68-70 B body, R QTY 0EACH $20.00
molding, stainless steel, roof rail, 69-70 B body, left QTY 1EACH $15.00
molding, stainless steel, roof rail, 69-70 B body, right QTY 1EACH $15.00
molding, trunk garnish, 69 Sport Satellite, fair QTY 1EACH $40.00
Motor mount bracket, on block, big block, w/ bolts, L QTY 3EACH $40.00
Motor mount bracket, on block, big block, w/ bolts, R QTY 3EACH $40.00
motor, power window, left, 66-70 B body QTY 4EACH $40.00
motor, power window, right, 66-70 B body QTY 2EACH $40.00
Nozzle, W/S washer, w/ hoses & tee, 68 C body, set QTY 1EACH $15.00
Nut, 1/4 glass adjusters, w washer, MINT QTY 4EACH $2.00
Nut, E-brake cable adjuster, MOPAR CORRECT QTY 1EACH $2.00
Nut, rear shock mount, lower, w washer, Mopar Correct QTY 2EACH $4.00
Nut, wing style, air cleaner, correct Mopar, large, 1/4 NC QTY 3EACH $2.00
Nut, wing style, air cleaner, correct Mopar, small, 1/4 NC QTY 2EACH $5.00
nut, wiper arm, , 5/16 NC w/ .875" captive washer QTY 2EACH $1.50
nut, wiper motor mounting, CORRECT MOPAR, set of 3 QTY 4EACH $6.00
oil cooler, power steering, HEMI, 440 QTY 2EACH $50.00
oil cooler, trans, series type QTY 1EACH $10.00
oil pan Big block, casting number 187 QTY 1EACH $75.00
oil pan Big block, casting number 402 QTY 1EACH $75.00
panel tail light housing area, 71 Challenger JH QTY 1EACH $75.00
Panel, access, inner fender, left, B body, 68-70 QTY 1EACH $10.00
panel, interior qtr trim, 69-70 body Ply, left, w/ fuzzies QTY 1EACH $10.00
panel, interior qtr trim, 69-70 body Ply, right, w/ fuzzies QTY 1EACH $10.00
panel, roof, 1969 ply B- body QTY 1EACH $300.00
panel,left door,blue, 71 Challenger, nice, JH QTY 1EACH $125.00
panel,left inside quarter,blue, 71 Challenger, nice, JH QTY 1EACH $125.00
panel,right door,blue, 71 Challenger, nice, JH QTY 1EACH $125.00
panel,right inside quarter,blue, 71 Challenger, nice, JH QTY 1EACH $125.00
PCV Valve, Hemi, Steel 90º, NOS in box PN 2808622 QTY 2EACH $75.00
pedal assembly, man trans, A body 71-76 QTY 1EACH $200.00
pedal assembly, man trans, B body 68- 70 JH QTY 1EACH $200.00
pedal assembly, man trans, B body 71-74 QTY 1EACH $250.00
Pedal pad, rubber, foot E brake QTY 1EACH $5.00
plug, clutch rod hole, 66-70 firewall, 2664330 QTY 1EACH $5.00
Plug, oil pan, various styles, Mopar original QTY 7EACH $2.00
plugs, body, original Mopar, asst'd sizes QTY 50EACH $1.00
Point set, new QTY 1EACH $20.00
power steering pump, c/w 77 440 brackets QTY 1EACH $80.00
power steering pump, no brackets, oval filler QTY 1EACH $40.00
pump, foot type man., A body 60's QTY 1EACH $15.00
Pushrod, fuel pump, Big Block all, NEW QTY 3EACH $19.00
radiator support, 1968 Chrysler Newport 22 ", MINT QTY 1EACH $10.00
radiator, 26" 3 core, VG, #3786949, C body only QTY 1EACH $150.00
radiator, 26" A- body, needs re-core, 3792918, W/ shroud QTY 1EACH $100.00
radiator, 69 C body, 383, 22" 2949041 QTY 1EACH $45.00
Regulator, voltage, original 1968, yellow printing QTY 1EACH $25.00
Relay, horn, 1968 - 70 original, restorable case QTY 1EACH $10.00
relay, horn, dated 0348, PN 2822461, mint QTY 1EACH $10.00
Resistor, 3 speed heater control, all 65-75 QTY 1EACH $25.00
resistor, ballast, CORRECT, 60-71 points ignition QTY 1EACH $10.00
retainer, brake drum, CORRECT MOPAR, QTY 10EACH $1.00
retainer, shoulder belt clip at sunvisor, A body, left QTY 2EACH $10.00
retainer, shoulder belt clip at sunvisor, A body, rt QTY 2EACH $10.00
retainer, throttle cable adjuster w/nut, new QTY 2EACH $10.00
Retainer, wiring harness, tape on style, QTY 5EACH $1.00
rockers & shafts,Adjustable Max Wedge, All RB eng, set QTY 1EACH $350.00
Rod, door latch, 68 C body, 5/16 X 6.5" QTY 1EACH $2.00
rods, connecting, stock, 400, 383 QTY 16EACH $10.00
rods, connecting, stock, 440 QTY 13EACH $10.00
Roller, torsion spring, trunk lid, B&C body QTY 2EACH $3.00
Rotor, distributor, Chrysler, new QTY 1EACH $6.00
Rotor, distributor, Prestolite, new QTY 2EACH $6.00
Screw, arm rest, all QTY 20EACH $1.00
Screw, door striker QTY 8EACH $1.00
Screw, fender tag, Mopar Correct, zinc plated as NOS QTY 17EACH $2.00
Screw, headlight aim adjuster QTY 1EACH $2.00
Screw, rear upper seat back retainer, MINT QTY 2EACH $2.00
screw, sill plate, CORRECT MOPAR, QTY 14EACH $1.00
screw, sill plate,SS, w/shoulder, 2 special, set of 12 QTY 1EACH $12.00
Screw, washer bottle, MOPAR CORRECT QTY 3EACH $2.00
Screw, wheel opening molding, correct Mopar, all QTY 52EACH $0.50
Screw,brake valve, frame mount, correct QTY 3EACH $1.00
Screw,splash shield on front frame, b body,correct QTY 4EACH $1.00
seal, e-brake cable, firewall, FITS MOST QTY 1EACH $10.00
Seal, grease,ball joint, NOS, B & C QTY 1EACH $3.00
Seal, pinion, 9 1/4 diff, new QTY 1EACH $10.00
Seal, rubber, 66-70 2DR HT, top of front dr channel QTY 1EACH $10.00
Seat, 1975 van, light weight for race car (Like A 100 van) QTY 2EACH $35.00
shifter assy, 1973 Challenger Slap Stik, w/linkage JH QTY 1EACH $150.00
Shim, door striker, R&L QTY 6EACH $4.00
shims, body and fender, MOPAR original QTY 12EACH $2.00
shroud, fan 26", 1977 BB N Yorker QTY 1EACH $10.00
shroud, fan, for 26" rad #3786949 QTY 1EACH $50.00
Sill extension, left, 68-70 B body, left QTY 1EACH $5.00
Solenoid, idle stop, 6 pack, new ~ QTY 0EACH
Spacer, transmission rear mount, rectangular, correct QTY 4EACH $2.00
Speedometer cable core, B body, all 66-74, & others QTY 1EACH $8.00
spring, bucket seat track latch, set of 5 QTY 1EACH $15.00
spring, hood release, MINT, 2.25" LONG QTY 1EACH $2.00
starter, early style, 1960-69 date codes, $100 & up QTY 20EACH $100.00
steering assy,complete, as new, 68 C body QTY 1EACH $100.00
Steering col. Ret brkt, bolt & plastic shim set, MINT QTY 1EACH $20.00
steering column hdwe mounting package c/w grd wire QTY 1EACH $15.00
steering column, tilt, truck early 80's, QTY 1EACH $20.00
Strap, aluminum, heater hose retainer, 62 & up QTY 1EACH $5.00
striker, door,c/w screws, LT, 65 - 75 most models QTY 0EACH $15.00
striker, door,c/w screws, RT, 65 - 75 most models QTY 3EACH $15.00
Striker, hood latch, model??? QTY 1EACH $5.00
Sunvisor, black, 68 C body MINT QTY 1EACH $25.00
switch, brake light, w/bracket, QTY 1EACH $10.00
Switch, door jamb, courtesy lights, most models QTY 1EACH $5.00
Switch, elec window, single, 70's, w/harness QTY 1EACH $20.00
Switch, electric trunk release, with bezel QTY 1EACH $25.00
Switch, headlight dimmer, 60-70 most QTY 1EACH $10.00
switch, ignition, 69 A body, c/w bezel QTY 1EACH $12.00
switch, p/window, master 2 gang, 75 & up QTY 1EACH $30.00
switch, p/window, master 4 gang, 70 & up QTY 1EACH $100.00
switch, p/window, single, 75 & up QTY 1EACH $25.00
tail light bezel, argent, left, 69 Valiant, c/w lens QTY 1EACH $25.00
tail light bezel, argent, right, 69 Valiant, c/w lens QTY 1EACH $25.00
tail light bezel, left, 69 Satellite, c/w lens QTY 1EACH $40.00
tail light bezel, right, 69 Satellite, c/w lens QTY 2EACH $40.00
tank, fuel, used, 70 Barracuda, decent QTY 1EACH $100.00
tank, w/s washer fluid, 68 -69 a body, man pump QTY 0EACH $0.00
timing cover BB QTY 6EACH $10.00
tires, Goodyear Front Runner, 24x5.0x15 QTY 2EACH $30.00
trans, 727 BB core only, QTY 1EACH $75.00
trans, 727 BB core only, 4 GEAR PLANETARY, HD QTY 1EACH $300.00
trans, 727, 1962, BB, with drum style output, RS QTY 1EACH $200.00
trans, A833 4 speed 23 spline, QTY 0EACH $0.00
trans,Manual, RR X-member, B-body, 66-70, QTY 0EACH $50.00
transmission, 727 auto, for 67 318 poly, c/w converter, QTY 1EACH $150.00
valance, lower front, 69 Sport Satellite QTY 1EACH $50.00
valance, lower grille, 69 Valiant, some surface rust, straight QTY 1EACH $40.00
Valve cover, cyl head, 318/360 74-75 pair QTY 1EACH $30.00
Valve covers, big block, Direct Connection chrome, PR QTY 1EACH $75.00
Valve covers, big block, various years, PR. $50 & up QTY 10EACH $50.00
valves and springs, rocker & shafts, misc BB ($ each) QTY 1EACH $1.00
valves, new, all B & RB, 2.08/1.74 full set QTY 1EACH $120.00
Vent , tube only, 8 3/4 diff hsg, plated as new QTY 1EACH $10.00
vent window actuator, C body, 66-70, left QTY 1EACH $10.00
vent window actuator, C body, 66-70, right QTY 1EACH $10.00
vent window crank handle, C body, 66-70, QTY 2EACH $10.00
Vent, diff, with brake junction block, all 8 3/4 QTY 1EACH $35.00
Vent, remote breather, diff & transfer case QTY 1EACH $5.00
Washer, upper strg col brkt, 8 sided, black, as new QTY 6EACH $2.00
water pump BB, New, Aluminum QTY 2EACH $75.00
water pump housing, BB, driver side outlet, 60's QTY 3EACH $100.00
water pump housing, BB, New Aluminum d/side outlet, 60's QTY 1EACH $200.00
Weather strip, v wing front door C body PN 2860718 QTY 1EACH $35.00
wheel cover, 69 Ply, #2823010, 14", 3 good, 1 fair (set) QTY 1EACH $40.00
Wheel, 15 x 5.5, JJ, 5 on 4.5" QTY 1EACH $5.00
Wheel, 15 x 6.5, 5 on 5.5", 86 truck QTY 5EACH $5.00
Wheel, 15 x 7.5, 5 on 4.5" Cop car wheels QTY 2EACH $50.00
Wheel, 15 x 8, Chrome, unilug, 3" backset (pic avail) QTY 2EACH $45.00
wheel, race only, alum, 15x12.5x4.5 BC w/8" back set QTY 2EACH $175.00
wheel, Ralley, 14x5.5/4.5 bc, with cap and trim ring QTY 8EACH $50.00
Window, 1/4, LT, 67-68 C Body Fastop, tint, w/frame mint QTY 1EACH $50.00
Window, backlite, 1968-70 Charger, clear QTY 1EACH $75.00
Window, backlite, 1968-70 Charger, tint ~ QTY 1EACH $200.00
window, backlite, 1969 Satellite & RR QTY 1EACH $75.00
Window, backlite, 70-76 duster/ Demon/ Dart Sport. Clear QTY 2EACH $75.00
Window, door, LT, 64-66 Cuda, clear, good QTY 1EACH $75.00
Window, door, LT, 67-68 C Body Fastop, tint, mint QTY 1EACH $100.00
Window, door, LT, 68-70 B-body 2 DRHT, clear, fair cond QTY 1EACH $25.00
Window, door, LT, 80's pickup, clear QTY 1EACH $40.00
Window, door, LT, Duster/Demon, 7 holes, clear, good QTY 1EACH $70.00
Window, door, RT, 64-66 Cuda, clear, good QTY 1EACH $75.00
Window, door, RT, 68-70 B-body 2 DRHT, clear, fair cond QTY 2EACH $25.00
Window, door, RT, 80's pickup, clear QTY 1EACH $40.00
Window, door, RT, Duster/Demon, 7 holes, clear, good QTY 1EACH $70.00
Window, door, LT& RT, 64-66 Valiant 2DRHT, clear, good QTY 1EACH $40.00
Window, LT1/4, 68-70 B body 2 DRHT, clear, weld spatter QTY 0EACH $10.00
Window, LT1/4,70-76 Duster/Demon,clear,w/wstrip & hdw QTY 1EACH $50.00
window, rear, 1971 Challenger, clear JH QTY 1EACH $50.00
window, right quarter 66-67 B body QTY 1EACH $40.00
Window, RT1/4, 68-70 B body 2 DRHT, clear, weld spatter QTY 1EACH $10.00
Window, RT1/4,70-76 Duster/Demon,clear,w/wstrip & hdw QTY 1EACH $50.00
Window, wing, LT 67-69 C body Fastop , TINT, w/frame QTY 1EACH $60.00
Window, wing, LT 73-76 Pickup , tint good QTY 1EACH $20.00
Window, wing, LT 83-84 Pickup , clear, good QTY 1EACH $20.00
Window, wing, RT 67-69 C body Fastop , TINT, very good QTY 1EACH $30.00
Window, wing, RT 67-69 Dart 2DRHT , clear, good QTY 1EACH $20.00
Window, wing, RT 68-70 Charger, w/frame, clear good QTY 1EACH $75.00
Window, wing, RT 73-76 Pickup , tint good QTY 1EACH $20.00
Window, wing, RT 83-84 Pickup , clear, good QTY 1EACH $20.00
Windshield, Shaded, 70-76 Duster/Demon, decent no chips QTY 1EACH $75.00
NO DOUBT A NICE COLLECTION! HOPE SOMEONE WILL PICK IT UP!
hey guys,spoke to vic,sounds like a hellava guy,had some good pricing,just shipping killed the deal.if you need something that is not listed,give him a call,he knows what he has!
Vic and i have dealt parts back and forth for years. really good guy. straight up no BS or games. The 340 listed is one that i sold him a few years back. good standard bore core.
looking for door glass (both sides) for a 69 swinger plus the rear bench seat, I am just down in Kelowna so will drive up to Vernon to pick up parts.
His parts list:
need a set of steel valve covers for a 1967-69 big block rubber grommett pcv on pass cover and push on oil cap on drivers side thanks jamie larsen:tongue9:
NEED 67-9 BARRACUDA GRILLES AND HEADLIGHT BEZELS. ALSO NEED 67 OR 69 CUDA REVERSE LIGHTS. ALSO NEED 67 OR 69 CUDA FINISH PANELS.
THANKS FOR YOUR TIME!!!!:axe:
For Everyones Information....
Got a email from Vic that his "complete collection" has been sold.
Hope he enjoys many long rides in the Charger now that he is fully retired.
i need a set of quarter panels for a 72 scamp/dart that i can cut up. located in northport long island 11768
i'm looking for fuel tank sending unit for 63 dart gt / slant 6 v-225 single barrel carb (i'm told there are two sizes available but not sure which one i need) . thanks
looking for 6138 thermoquad 1972 340 manual trans and assoc. parts
thanks Bob
the smaller one. the larger would be more adequate if you had an engine that was bigger than the slant, thus needing more gas typically.
This is for the guy that bought the collection. I need a throttle rod as shown in the picture. It is part #12. This is for a '73 Dart (318 with Carter 2 BBL). Thanks.
my name is tom klaeser i am looking for a deck lid for a 1970-71 duster or 1971 dodge demon
PM me
