Brandini
Active Member
Rebuilding the front suspension on my 69 Barracuda and was able to remove the old bushings as well as the pin/bolt that takes the nut on the k member. What is the method for reinstalling the pin into the bushing or should the bushing be pressed in before the pin is pressed in. Thanks in advance.
