Im woundering if these are the lower control arms with sway bar tabs> Like to know before i say they are when i go to sell them thanks Edd...Always learning especially from you all.
If you could post a side view of them I could tell you what year they are from, and if you give me a closeup of the pivot shafts, I can confirm the body style application!!! Geof
In your top picture:
The top left LCA is from the 73-76 sway bar equipped cars.
The top right LCA doesn't have a tap, so technically it will fit anything.
The LCA's on the bottom of the picture are for 65-72 sway bar equipped cars.
