[Found!] LCAs with swaybar tabs
DusterDaddy
sledgehammer mechanic
Holmdel, NJ
Looking for a set of lower control arms with swaybar tabs for a 74 Duster
I can send a UPS label for shipping.
FYI
Better let people know what year car your wanting them for.
65-72 cars use a different style tab, and 73-76 cars use another style.
Just FYI, the aftermarket reproduces those tabs ( to be welded on ).
I am aware and can weld. How do you determine location?
If aftermarket doesn't include some point to point measurement... Pictures of OEM for visual reference. That tab is about the middle of the arms length. The end links have enough movement to absorb at least a 1/4 inch wrong one way or the other. No rocket science req'd. I could provide some measurements of OEM laying loose here ( not for sale ).
Thank you. A straight down photo close to center would be very helpful. I can enlarge and reverse image to use as a template.
Much appreciated
Would mounting the bar to the K then centering it up, hanging the mounts with the bolts, then welding them where they rest on the arm be viable as opposed to eyeballing them off a photo?
I ask because I am going to be mounting a anti-sway bar And that’s how I thought I would do it.
I was going to enlarge the photo to actual size to use as a template. Easier to weld on a bench than laying on the floor. besides, I don't own the swaybar yet, just planning to rebuild the suspension now.
