I have a 65 Barracuda 273 auto. I was looking at the leaf springs and I count 6 leafs per side. Are these stock springs? If so are the heavy duty? It does not have a front sway bar.
X2...also rated @ 115lb spring rate. I have the front sway bar but it came standard on my '66 Formula S as well as the '65 F/S. I got replacement ones for Spring n' things. Mine were original to my car and sagging a bit...big difference in ride now.
I too have a 65 Barracuda with the same springs I believe are original to the 273 auto with no front sway bar. Mine did have the dealer installed front disc brakes.
