I had a leak at the front of the oil pan, tried the stop seal spray stuff. Seemed to work for awhile, stopped most of the leak, just a tiny drip now, but I can't identify exactly where from. It's in the front. It's definitely not the crank seal in the timing cover or the timing cover to block, it's the oil pan gasket. I believe it's at the top front corner(s).
So, for now, since it's a very slow leak I'll drive it, but at some point I'm gonna pull that oil pan and reseal it. You all helped me with the rear China wall leak, great advice there. Have any similar advice or tutorials to point to on the oil pan gaskets? Looks like if I unhook the center link the pan will drop right out.
Brian
Brian
